I have created a tag. I want it to read the filename.
I can not add a field (or do not know how).
Is there not a variable or something I can use to automatically add this data?
Something like $filename$ or the like.
Unknown said:I have created a tag. I want it to read the filename
You can't do that with tags alone, I'm afraid.
You could write some VBA code to do that. Alternatively, take a look at text fields (MicroStation V8i) or ItemTypes (MicroStation CONNECT), both of which may do what you want.
Please clarify which version of MicroStation you are using.
Unknown said:Text: %Production Data%... etc What is the percent signed used for?
No idea. It's nothing to do with MicroStation tags. Can you post a small sample DGN file?
Here is a sample of a similar client that is posted on a public site.AEC_G-001.dgn
Unknown said:Here is a sample of a similar client that is posted on a public site
Thanks!
I can see four tag sets defined in that DGN file. Key-in DIALOG TAGS SETS to see what I see. The tag sets and tag definitions all have regular names.
Some of the tag values have percent sign prefix and suffix (e.g. %STATUS%). That idiom must be something that your client uses for his own purpose.
