Just tried to Pattern Area to find that in U3 this is now not working. I'm getting a message that no cell pattern defined which is not correct.
In the same file this works fine with SS4.
This is something I use on a regular basis so is a complete pain to find it not working!! When is this likely to be fixed?
Hi Stuartw,
I tested Pattern Area using specific pattern defined from a Cell library and everything seems to work for me in Update 3
Could you please press the Browse Cells and when the cell library opens make sure the Set active pattern cell is turned on
If this does not work for you, please send us your file for testing
Maria
