Element Handles Aligning to View
Posted this in Visualisation but realise that's the wrong place for this query so I'll re-post it here:
I'm running SS3 08.11.09.459
As of this morning element handles are aligning to my view when I place cylinders, rather than staying in the alignment that they were drawn in. I am expecting the outer handle that defines the radius to stay aligned to the axis it was aligned to when I created the element. For example, if the radius handle was aligned to the Y axis when it was created, I expect it to stay aligned to the Y axis regardless of my view position.
As far as I recall I have not changed any settings. I created a new 3D drawing with the default 3D seed this morning and that is when I first noticed something was different.
The video below also shows how sometimes MS toggles Alt when i grab a handle. By default i expect to adjust the radius of the entire cylinder, now its turning the cylinder into a cone.
This behaviour is the same for all existing cylinders in the drawing and all new cylinders that I place.
This screen grab may also help:
I'm getting two sets of handles for the same element selection. The handle direction indicated by the red arrow shows the tow origin points i placed when creating the cyulinder, that's all i ever want to see. If i go to isometric view, i no longer see the origin handles of the element. I end up seeing an outer handle that is aligned to my view.
I've never seen MS do this before. Is there a setting like, align element handles to view or something like that?
Josh
