If I place a note using the Text Frame = Box with a leader I can edit the note. However if I place the same note without the leader MS doesn't allow me to edit it.
hi DavidG, I have reproduced the issue on my side. I will file a Defect now and follow up with you via SR. Regards Maria
Answer Verified By: DavidG
