I have a problem. After you install the Microstation powerdraft doesn't control the entire program. When you choose such as drawing the line of me does not respond as other features. Do not work or the bookmarks file, tools and more. What could be the problem?Thank you for the advice.
Unknown said: When you choose such as drawing the line of me does not respond as other features.
Is this related to graphic issues?
communities.bentley.com/.../368072
José
Hi Kateřina, as Sumit wrote, it would be helpful to know what PowerDraft version (build number) do you use and also in what Windows. Or we can discuss your issue in Czech if you will contact me at jan.slegr@labtech.cz. With regards, Jan
