I would very much like to change or even better insert another cell instead to the Bentley's standard balloon when inserting dynamic views into a sheet, as shown below.
I have spend a lot of time searching for the cell libray without any lock.
Can anyone help ?
Thanks in advance
Ole Bro
Hi Ole,
I recommend you to have a look at these wiki articles:
communities.bentley.com/.../how-can-i-create-custom-detailing-symbols
communities.bentley.com/.../drawing-boundaries-a-solution-for-accelerating-sheet-creation-and-layout
http://communities.bentley.com/products/microstation/w/microstation__wiki/24770.drawing-boundary-not-available-when-using-place-named-boundary
You can also visit LearnServer to review what courses are available, example detailsymbol style. See>> Customizing the Dynamic Views Workflow
Maria
Maria Garcia
I could replace the Bentley default by such a section symbol. If I remember correctly, I hat to add to one of the DGNLIB files and let a Config Variable point to that like MS_SECTIONSYMBOLDEFAULT. It was quite complicated.
