I just pulled out the AccuDraw dialog box from being docked and this is what I'm seeing.
How do I get this to go back to how it looked in earlier versions? Yes, I am in a 2d file.
Unknown said:How do I get this to go back to how it looked in earlier versions?
Earlier versions of what? What is the current version?
Hi Andrew,
Unknown said:Which particular version had you seen this smaller dialog within?
I don't know what version Dbl J D uses, but I checked MicroStation V8 2004 Edition and the dialog is small there, not the big one with empty not used space.
With regards,
Jan
In V8i SS2 08.11.07.443 I get the small version in a 2D model.
Dan
Thanks Dbl J D,
The version of XM I was looking at was the last release (08.09.04.88) and I can only see the same height of the AccuDraw dialog but I do see in V8 2004 that it was shortened when in a 2D file.
Thanks also, Derval, for that detail for the Dialog Size under the AccuDraw Settings. It only seems to adjust the length of the dialog and not the height.
I have raised Enhancement Request # 623891 to look at the height of the AccuDraw dialog. You could raise a new Service Request which we can link this to so you can monitor its progress.
Unknown said:Andrew, I used XM when I worked from home, that's where I remember that it looked like the image. Lorys, I used "print screen" and edited the png I created using "Paint". What would be the purpose of making the Accudraw dialog larger than it needs to be?
Wow that was so long ago I forgot that there even was this difference having become so accustomed to the V8i series over the last 10 years you do get used to stuff....
Lorys
