Merge Rail Long Section with Overhead Plan Route
A little stumped on how to get the result I'm after.
Here I have an elevation long section (bottom red line) and an over all plan view of the new rail route (top red line). White lines mark 100m incraments, total length is 1800m. I need to merge the two to produce something similar to the top red line but when viewed in isometric view you'll be able to see the rise and fall in the route shown in the long section.
All I have access to is MS SS3, is there a way to wrap one line along the path of another but keep Z levels?
Josh
  • Following on from Makai's suggestion you could perform similar operation with MicroStation :
    1. Create a complex chain of the curved plan elements ( Note one of the segments needs to be moved to the correct Z value to match the others - See image below ).
    2. Use the Construct Points Along element (Points:18) and select the start (left side) and end of the complex chain.
    3. Select all the newly created points and export them to plan.txt file using the 'Export Coordinates' tool
    5. Repeat steps 1-3 above of the Line for the elevation and export the coordiantes to a file called 'Elevation.txt'
    6. Replace the Z values in the plan.txt with the Z values in Elevation.txt and save as Combined.txt
    7. Use the 'Import Coordinates' tool to bring in points using Combined.txt ( Attached )
    480.6682,655.1089,0.0000
    479.2011,555.3773,0.0000
    508.4428,460.2295,-1.5811
    567.2073,379.8871,-3.5810
    649.0254,323.1952,-5.5808
    744.8914,296.4176,-7.5807
    844.5999,289.4368,-9.2000
    942.3812,308.0634,-9.2000
    1029.1020,357.1043,-9.2000
    1110.4822,415.2222,-9.2000
    1191.8624,473.3400,-9.2000
    1273.2427,531.4579,-9.2000
    1345.2595,600.1956,-9.2000
    1390.9012,688.6547,-9.2000
    1411.8347,786.3763,-9.2000
    1430.6535,884.5917,-9.1892
    1436.7241,984.0810,-5.2174
    1452.1632,1082.4684,-2.7000
    8. Create new curve from these newly created points if required.
  • Removed posted information as posted too early - Currently unable to delete this.
  • Thought I had the solution but it turned out to be wrong. Going to go with InRoads.
    Answer Verified By: Josh WHEALY
Reply Children
    I have not tried it yet  but  the  3d  line  is the  one with the  z values if you extended, copied it  parallel  it  to cover the  width of the 4 extremes ie  x and y without changing its  z
     then created a surface from those to lines
    next  chain your curved line  and then  project it  onto the  new surface  this can even be done  with it in a ref file , the  stencil tool should turn your 2d  curve into a 3d  line string
    We used to be only  able to do this in inroads but since ss3 the  stencil tool can now drape  or project 2d linestring onto a surface...
    Lorys
    click link to PM me
  • I don't see how this would work. You're projecting the alignment (the curve) whose points won't fall on the surface, which has the curve points "streched" out to form a straigh line.
  • I was theorizing  how it could be done,  I have done it before but not with his data set.
    the sloping  horizontal  was assumed to be  real 3d  vertically  and the curve is 2d geographically correct with z=0
    then we would  put the 2d curve in a 3d file own its own with z=0 ( also it would be chained as one element)
    the  slopping  line ( which turns out is really only 2d in a 3d file)  has to be interpreted to work out  the relative Z based on the  slope and relative to each end if we can create a new 3d file and ref attach our new curve file ontop we can work out the  extend or boundary  for our  surface extent , then we can create a polygon left to right that  would be the  same  slope above  0 as was the  sloped line but has z values
    Then we can turn this  polygon into a surface, then use the  stencil tool to drape  the curve onto the  surface ( just like in inroads but all with microstation)
    The result is the  curve has  x,y  and  now real z values not  0...
    The hard part is creating the  surface from the 2d line that was drawn in a 3d file originally
    I  have done this with the stencil tool  in ss3 before  but I created the surface from a survey file  with either points or contours... so it  should be achievable for someone that doesnt have access to inroads and only msnt ss3  minimum...
    Lorys
    click link to PM me
