Good Afternoon,
I'm having trouble resolving the display order issue depicted below, specifically the leader/terminator part of the callouts. As you can see the text is displaying properly (in front of the grayscaled survey), but the leaders/terminators are plotted behind the grayscale. I double checked the update sequence and adjusted some display style settings as suggested in other posts, but nothing seems to be working. Another sheet in my plan set is not experiencing this issue, but I can't determine the difference between the two. They're both using the same pen table so I doubt that's the source of the problem. I'm using microstation v8i select series 3. Any help would be much appreciated.
Thank you,
Colin
Power InRoads v8i V08.11.07.615
Microstation CONNECT U13 10.13.01.01
ORD CONNECT 2019 Release 2 U7 10.07.03.18
ProjectWise 10.00.03.217
