1 - Create a saved view with a certan name
2 - Link the saved view into an object.
3 - Rename the saved view
4 - The link is lost.
Is this WAD or the link should update?
Hi Jose, I have filed Defect 625789. I will follow up with you via SR as I am not sure if this is WAD.
At the moment the only workaround seems to be Editing the links
and from Properties go to View Name and pick from there the correct new saved view name.
After doing this the link will follow the saved view again
Regards Maria
Answer Verified By: Jose Pinho
