Where to edit these settings?
Where can I edit this default values?
Regards.
Christiaan
  • Hi Christiaan,
    What MicroStation version are you using?
    I believe in V8i the borders folder is available From C:ProgramData<Bentley MicroStation v8i (SELECTseries)workspaces<systems
    If working in CONNECT I think the folder is under C: Programdata<Bentley<CONNECT Edition<Configuration<Workspaces<Examples<WorkSets<MetroStation<dgn
    Review this Blog as Sheet Border is explained there communities.bentley.com/.../introduction-to-sheet-border
    Note: the default sheet sizes are referenced from the sheetsizes.def file .
    If you want to create your own customized definition copy this file sheetsizes.def to your corporate workspace folder. Use the variable MS_CUSTOMSHEETSIZEDEF to point to your file location.
    Sheetsizes.def is normally saved in the Data folder
    In CONNECT C:Program Files\Bentley\MicroStation CONNECT edition..\MicroStation \Default\Data\sheetsizes.def
    for V8i I think is ...\Workspaces\System\Data\sheetsizes.def
    I recommend you to review Customizing Sheet Sizes in the Sheetsizes.def file in  MicroStation Help
    also review this wiki:
    Maria
    Answer Verified By: Christiaan Post
  • Hi Maria,
    Thanks, I use a lot of different versions from MicroStation to Railtrack PowerCivil and ORD connect editions :)
    I see this file is responsible for the input:
    C:\ProgramData\Bentley\MicroStation V8i_08.11.09.459\WorkSpace\System\data\sheetsizes.def
    Christiaan
Reply Children
