There is an issue with the display of referenced dwgs in CEU3 using bylevel symbology. See below. The top one is from SS4, with the second one being the same sheet model in CEU3.
When is this going to be sorted out. At the moment CE is useless to me if it bylevel symbology doesn't work. If I open the drawing in SS4 then all is OK, but looks completely different in CE. This is basis stuff as far as I'm concerned and needs resolving asap.
If you can supply either the defect number or the SR number we can check the status..
The SR number is 7000600266 and Defect 659785
It has been noted by software development that Defect # 659785 is reproducible and has been approved for a future release of MicroStation CONNECT. Most likely it would be Update 6 or 7.
Andrew, It needs to be update 6, as update 7 is too far away!! This is a show stopper for me, because if a drawing doesn't look right and therefore doesn't print right what is the point. Back to SS4!
