There is an issue with the display of referenced dwgs in CEU3 using bylevel symbology. See below. The top one is from SS4, with the second one being the same sheet model in CEU3.
Unknown said: In addition can you confirm the same configuration is used in both instances, variables like MS_LEVEL_EDIT_NESTED_ATTACHMENT_LEVELS, MS_LEVEL_AUTO_SYNC_ATTRIBUTE_LIST may have a bearing.
SS4 - both configs are set in my 'standards.cfg' with MS_LEVEL_AUTO_SYNC_ATTRIBUTE_LIST set to Bylevel Colour.
CEU4 - both configs are set in my 'standards.cfg' with MS_LEVEL_AUTO_SYNC_ATTRIBUTE_LIST set to Bylevel Colour, but MS_LEVEL_EDIT_NESTED_ATTACHMENT_LEVELS is showing as set by the system.
Thanks for providing the additional files we have reproduced the problem as described and will file a Service Request / Defect on your behalf to have this addressed in a future build.
