There is an issue with the display of referenced dwgs in CEU3 using bylevel symbology. See below. The top one is from SS4, with the second one being the same sheet model in CEU3.
I tested this in v8i also. Though it makes the attachment to the non active directory file during the active session (regardless of Save Relative toggle) when the file is reopened it resolves to the reference file in my active files directory. Did you find this happens also?
RobertArnold said:This is a change from Mstn V8i to Mstn CE. With V8i, you were able to attach the specified file.
~HTH
John.
yep
Yes.
--Robert
Odd wonder why its not working for me once its saved.
This is still not fixed in U13. I have just tried the data set shown in the screen shots in U13 and SS4 and am getting the same results. I know that you let me have a config variable to resole this issue but that changes all dwgs. I just want this file to display correctly. When will this be fixed?
Anyone from Bentley care to respond to this? This has been going on way too long now.
This is still hasn't been resolved in U14. I know that there was a work around posted but I should need to do this. Is this on the list of items to be resolved any time soon?
This thread started in December 2016 and still not sorted!!
Following further review with Stuart, whilst Defect 659785 implemented in Update 12 did address the color display issue, such that CONNECT Editions matched that of V8i.
An additional requirement was to have the ability on a per DGN file basis, to modify the colors of a referenced DWG Shared Cell. Whilst this is possible, it was found that the changes were not permanently saved and as a result not reflected through to the Sheet model.
Thus as result a new Defect 1094743 has been raised, and scheduled for Update 15
Carl Myhill
Technical Support Engineer
Bentley Systems
