Hi
Is someone else having this problem that the variable
MS_RASTER_DEFAULT_LEVEL=
doesn´t work in MS SS4?
regards
Tom
I load the variable at Site level, and you probably at user level. If so why is this level sencitive?
//Tom
Hi again
Tested to load the variable at user level but it doesn´t work.
Here is all the capabilitys and variables I use:
_USTN_DISPLAYALLCFGVARS=1_USTN_CAPABILITY < -CAPABILITY_LEVELS_USE_AUTO_GENERATED_NUMBERSMS_PROTECTION_ENABLE=0MS_LEVEL_DISPLAY_FORMAT=N(D)MS_HIDE_LIBRARY_SOURCE_NAMES=1MS_PLT_INVERT_WHITE_COLORS=0,7MS_BROWSERMAKECHILDWINDOW=1MS_V7TOV8_DELETE_UNUSED_LEVELS=1MS_LEVEL_EDIT_NESTED_ATTACHMENT_LEVELS=1MS_DISABLEWINDOWGHOSTING=1MS_FULLPATHINTITLEBAR=1MS_RASTER_DEFAULT_LEVEL=RASTERMS_OPENV7 = 3MS_COMPRESS_USER_PREFS = 1MS_REF_NOSTATUSCOLUMN = 1MS_REF_DEFAULTSETTINGS = displayRasterRefs=0,trueScale=1,attachMethod=world,useAnnotationScale=0,nestDepth=2MS_LEVEL_USE_ASCII_NAME_SORT = 1MS_DWG_REFERENCE_CONVERT=OFFMS_DWG_CONVERT_RSC_FONTS=ONMS_NO_DWG_BACKUP = 1MS_DWGAUTOSAVE_NODIALOG = 1MS_DWGAUTOSAVE = 30000
Timothy Hickman
Main: 877 627 3772|
Hi Tim
No there is no Raster level in dgn file.
when I use SS2 the level is created automaticly through the MS_RASTER_DEFAULT_LEVEL=RASTER
What I suspect is that it is not enough to only set the MS_RASTER_DEFAULT_LEVEL=RASTER to automaticly get the RASTER level created.
I probably need to create, MS_USERPREFSEED=XX .sdf where I Set the Preferences/Raster Manager/Default Atributes all to OFF and Set default settings level to RASTER.
I don´t get it to work only with MS_RASTER_DEFAULT_LEVEL=RASTER what is strange when Melissa got it to work when she tried.
Strange and I don´t have any idea why MS_RASTER_DEFAULT_LEVEL=RASTER doesn´t work for me as the only variable to set this!
I rather not create MS_USERPREFSEED and wait and see if someone is finding any solution to this (or if I find the problem)
