We are working in Microstation Powerdraft V8. Could someone tell me how to count cells? I know there is a way through the MDL app's but I cannot find it. If anyone has an easy way to do this please let me know. We're trying to count plants in our dgn file and it's very tedious counting them on the hard copies.
Thanks!
There are some tools that can count cells...Not sure I have one lying around.
A rough way to get some numbers, is to use Edit -> Select By Elements and filter by cell name. Execute the selection and check the message bar at the bottom of your screen for the number of elements in your selection set.
MaryB
If you have not yet, you might want to take a look at CellCounter, as that does what it sounds like you are looking for.
That's exactly what I'm looking for - thank you Phil
TG
Phil, how do I get to CellCounter?
The file "moved" from its original location... that has been updated in the link in the previous reply. Thanks for pointing that out.
