Hello all,
Microstation V8i SS3 08.11.09.459
I have read the other posts on this topic where users have posted about Google Earth exports from a DGN showing up with a 20-30 ft offset. My issue is similar but the offset is by a few states and not a few feet.
I received a DGN from a colleague and there is not any historical information available about who created it (this is for a project that was shelved for a while). The goal was to export it to a KMZ. In the past, I haven't had any issues with similar exercises with other files. I would set the appropriate GCS using the Geographic toolset and then export it to a KML and it would show up in the correct location.
Similarly, this file did not have a "current" GCS assigned to it when I opened the "Select Geographic Coordinate System" window. So, I chose the "TX83-NCF - NAD83 Texas State Planes, North Central Zone, US Foot" system based on the project's physical location (just south of Athens city limits in Henderson County, TX).
When I export the KML, it shows up in one of the midwest states (Iowa I believe). Here is what I tried doing:
1) Exported the DGN to a shapefile and tried ArcGIS's Unknown Coordinate identification exercise as given here - http://support.esri.com/technical-article/000006217 . I was unable to figure out the original coordinate system that was assigned to the DGN.
2) The NAIP aerials I have for this area are in UTM Zone 15N (meters) coordinate system. SInce the DGN is in US Survey ft, I made a futile attempt at transforming the aerial's coordinate system to the same as the DGN's and manually overlaying the linework. I wasn't entirely sure about what I was trying to accomplish here!
Could someone please explain what my mistake here is? Eventually, my goal is to export this dgn to a kml and make it show up in the correct location. Thank you,
Unknown said:My goal is to export this dgn to a kml and make it show up in the correct location
Your goal should be to get the model to show up in the correct location in MicroStation.
Once that's achieved, other goals should fall into place.
Are you able to post your DGN file here?
/cfs-file/__key/communityserver-discussions-components-files/273/Existing.DGN
Jon - Rightly said!
Please see if the above link works, I uploaded it there. Also, I did a secure upload of the dgn and aerials since they exceeded the 20MB limit. The post ID I used for the secure upload is http://communities.bentley.com/products/microstation/f/273/t/129568 . Would you have access to the securely uploaded files? Or, is that only for Bentley employees?
Vinod
Rod WingSenior Systems Analyst
Answer Verified By: Vinod Balakrishnan
