Is there are way to prevent the active level from changing when I select an element and change its level.
Current behavior: Select element, use drop down to change level, element level changes and selected level is now active
Desired behavior: Select element, use drop down to change level, element level changes and active level remains the same
Thank you
Jacob
Timothy Hickman
Main: 877 627 3772|
