I've seen this happen before and it seems to occur only in certain files.
Using the Place Note Command, with In Line Leader Enabled. During placement, all looks well. As soon as the command completes and a new command is started, or if t a new Note with the same text but at a new location is identified, the in line leader vanishes.
I toggled the Start at between Text or Leader and the result is still the same.
I tried changing the dimension styles and leader length but the result is the same.
Surely others have seen this and it has been reported. This is not a DWG issue as far as I know - I'm in a 2D model of a DGN file.
Was this problem resolved? This has happened to me in Microstation SS4 (08.11.09.832)
Could you please post a file for testing?
Derval Canny.
WE'VE GOT THE SAME PROBLEM HERE. NO SOLUTION.
