We have got several cell elements that contain dimension elements.
Very often its necessary to resize the cell elements after they have been placed into a drawing.
The users resize the cell elements using the 4 corner spots:
How can we prevent that the dimension values are changed when the element gets resized?
Unknown said: We have got several cell elements that contain dimension elements. Very often its necessary to resize the cell elements after they have been placed into a drawing. The users resize the cell elements using the 4 corner spots: How can we prevent that the dimension values are changed when the element gets resized?
create a sub model place your cell there and self ref attach the sub model and scale by points the reference it should not change the dim values just make the image bigger.... if doesnt work as intended return to the sub model and drop the cell and drop the dimensions return to default model and scale ref should be perfect!
Lorys
I Hope This Helps Someone Reading This! (Intergraph>PseudoStation>MicroStation user since 1980's)
Answer Verified By: quasi_modo
Unknown said:Just edit the Dimension in the Cell model to text, so the asterisk " * " does not display. The * in the dimension tells MicroStation to place the actual dimension in it's place. The Text and dimension elements will still scale but the text in the dimension will not change.
so they look like dims but no longer are dims, they are just lines and text.....
And you the Experiended guy know to go to all the cell models needed and do it for your less experienced guys and they wont even know its been done..
But I still prefer to use scale proportional cells via place cell and turn on the scale only and interactive mode, then only need 2 points in one direction as in your example the text is distorted
