I cannot find a configuration variable to turn compress file one exit "on" by default for new and existing users. Does one exist or doe sit have to be manually activated?
In this situation the configuration variable you'd use is MS_USERPREFSEED for new users.
The process to create a UPF is outlined in the following:
http://communities.bentley.com/products/microstation/w/microstation__wiki/17493.create-a-seed-user-preference-file-spf-that-does-not-contain-file-history
Once created you can set MS_USERPREFSEED to point to the desired seed preference file.
For existing users they will have to turn that option on manually..
Answer Verified By: Grant Wood
