Since I have loaded MicroStation CONNECT I have not been able to get command line arguments to process. For example, using this line to start MicroStation:
"C:\Program Files\Bentley\MicroStation CONNECT Edition Update 3\MicroStation\microstation.exe" -wr\\HSSIENG\Resources\HS\MS-CONNECT\CONFIG\
does not process the WorkSpaceSetup.cfg in \\HSSIENG\Resources\HS\MS-CONNECT\CONFIG\
It worked fine with Update 3.
Unknown said:"C:\Program Files\Bentley\MicroStation CONNECT Edition Update 3\MicroStation\microstation.exe"
Typo?
Timothy Hickman
Main: 877 627 3772|
most likely you will want to use the following switch instead -WC<path_to_configuration_file> Specifies the configuration file MicroStation will use on startup (for example, -wcC:\Bentley\Workspace\Config\myconfig.cfg).
