MicroStation V8i + PowerCivil crash when rendering big graphical object, but a lot of this graphic is probably saved somehow and somewhere... File have now over 200 megabytes, but nothing visible, all levels are unused. Only VBA scan found some nongraphic elements, but can not be deleted. And also I do not know if these few (<100) model elements have 200 megabytes. Although I easly find from what model they come, but still i cant delete them, becuse "model.removeElement ele" throws error -2147218397 (bad modelRef). Is there any way to delete these elements through Microstation, programming language or any utility?
File contains also few (<50) nonmodel objects, but that is all what i found. And I have no idea if they are deletable or how delete them.
Does File|Compress do anything?
If not, you may want to post the file here to give someone a chance to analyse it.
Hi Petr,
Unknown said:File have now over 200 megabytes, but nothing visible, all levels are unused.
In my opinion the best solution is to use backup.
Unknown said:Only VBA scan found some nongraphic elements, but can not be deleted.
VBA is not right tool to access DGN internal structure, because VBA is high-level API, so many details are hidden and also not all DGN and MicroStation features are accessible from VBA.
Unknown said:And also I do not know if these few (<100) model elements have 200 megabytes.
Probably not, but some data structures (DTM, meshes, interal data structures) can be very large.
Unknown said:s there any way to delete these elements through Microstation, programming language or any utility?
I agree with Jon that to compress the design file (with all option switched on) should be the first step.
As the second, you can try verifydgn utility: key-in is "mdl load verifydgn; verifydgn repair" (or verifydgn repair alternatively) and to check in Message Center details, what is reported. The utility is not very powerful, but it can provide some extra information in the case the file is corrupted.
To access DGN directly, MDL should be used. But a question is if an expected amount of work is equal to potential benefits.
In some cases it can be hard to delete some elements, because they can depend on another, which makes the analysis more complex.
With regards,
Jan
If I have a fresh backup, then I use it. The first thing I tried was to delete what I can and I checked if this have any effect. After each change file are compressed and saved again. I tried to open the damaged file as reference and copy from it what I need, but this is also bad way (copies only graphic). I understand VBA is not the best, but slightly better than user tools and it's something what I know, unlike MDL.
mdl load verifydgn - no error found
I attach a file.
www.uschovna.cz/zasilka/LIPJRX2GFDJL4467-XYT
PowerCivil for Czech Republic V8i (SS4) 08.11.09.790
I Hope This Helps Someone Reading This! (Intergraph>PseudoStation>MicroStation user since 1980's)
