Hello ,
when I save my model in V7 then file size are increase, How to decrease there file size?
Hello, You should keep in mind that the V8 file format is a compressed DGN format, were the V7 file format is not. This means that for the same DGN the size as saved in V8 format will be smaller then when saved in V7 file format
See the AskInga Community wiki: V8 file size compared to V7
René R. van den BrinkTechnical SupportBentley Systems Incorporated
Answer Verified By: SONU KUMAR VERMA
