I have a lot of files that need to have these settings changed. I need the Master Unit label changed from ' to FT; Sub Unit changed from Feet to Tenths and have the Accuracy changed from 0.12 to 0.123
So I'm wondering if there is a (or some) keyin that will reset these 3 Linear Unit settings.
Thank you
Cheers,
Erik M.
Attached is a seed file that I am having problems changing the subunit to tenths. Can you help me modify all the settings to change it to tenths and keep all the other settings I have.
e8547.2dseedZone2.dgn
MicroStation V8i (SELECT series 3) - Version 08.11.09.578
Microstation Connect 10.14.00.109
This post seems to be a replication of other discussions you have started in relation to the same query. It is also against a discussion that is three years old. I would suggest you continue this discussion on your existing posts.
