I have just uninstalled CEU4 and re-installed, and set the custom configuration to pint to our server location. This is not working as I'm getting the default GUI and tools, with nothing being picked up from our server location - no levels, tools, tasks, etc. I have had to copy over our standards.cfg to C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\Organization to get it to work but even that is not bringing our levels, text styles, dimension styles, which are in the server DGNLIB. I am getting my customised right mouse click pop up.
I have thye following set in my server.cfg.
MS_GUIDGNLIBLIST = i:/CONNECT-workspace/standards/dgnlib/gui/ws-gui.dgnlib
MS_DGNLIBLIST > i:/CONNECT-workspace/standards/dgnlib/gui/ws-gui.dgnlib
Why doesn't this work?
CONNECT.cfgAttached as requested. Located at "I:\CONNECT-workspace\"
Have you run MSDEBUG and examined the results?
There are some questionable configuration variable definiions. For example...
_USTN_WORKSETSTANDARDSUBDIRS = _WS Current Issued Drawings
If that's intended to be a folder specification, then it's broken. There is no trailing slash. The effect of that statement is to assign _USTN_WORKSETSTANDARDSUBDIRS the value _WS. Examination of the output from MSDEBUG would help you to find problems like that.
There is a number of definitions where a trailing slash would be beneficial...
_USTN_WORKSETSTANDARDSUBDIRS > 1 WS-Architect/Construction
