I am having great difficulty with modifying a non parametric 3D model in Connect edition, if I cut a solid and delete the cut line everything disappears.
Is there a way of replicating the work space an methods I used in V8i withConnect edition of Microstation
Timothy Hickman
Main: 877 627 3772|
Hello Martin
Regarding the cutting of the solid, could it be that when you cut the solid the 'Cut Solid with Curve' tool setting 'Profile:' was defined as ' Show ' ?
If this is the case if you select the solid you will see glyphs appear, right click on the 'cut' glyph and you can select the option ' Hide Input Element '
See help for further information
Carl Myhill
Technical Support Engineer
Bentley Systems
