CE - Sheet index sheet name (tag/field)
All
is there a way to read the existing sheet name and apply it to the sheet index.  A lot of clients if not all, use either a TAG or a text Field to populate their sheet name.  This can either be automated via the DGN name or manually edited via a TAG or worse case its dumb text.
When we add sheets to the sheet index it doesn't allow us to look for these TAG/Fields etc. Thus we end up with a sheet index that has sheet names as A001, A002, A003 etc.  As you can imagine, thus is useless.
Question: How can we populate the sheet index names when adding them to the sheet index and read a tag or text field.
Without this option.. I am sorry to say but SHEET INDEX is useless.
Ian Lapper
Advanced Integrated Solutions
Parents Reply Children
