All
How can I add titlblock TAG data to the sheet index. The reporting tools for the sheet index is a good idea. I can see that you can populate a series of defualt items such as sheet index, filename, etc. However, it would be a massive benefit if we can add the sheet titleblock TAG data to the reporting tools, this it would be 1000x better.
Thus if I have a sheet with a TAG set that includes Title 1, Title 2, Tile 3, Scale, Revision. and be able to add this to the reporting tool. Plus an option to add my own data such as; issues to, date etc
The sheet indexing becomes part of a company standard and one that can be pushed to excel to give the users a HUGE benefit in something that is a time constraint on a good day.
Ian Lapper
Advanced Integrated Solutions
To add to this discussion.
In Revit they use schedules to populate the revision history. My line of thoughts re to harvest the item types to give users greater control over the titeblocks, issue sheets, etc. One massive advantage would be to use reports to populate the revision history.
Has anyone tried this?
Ian
Jon
Having the export to excel is one thing but to be able to manage the revisions on the sheet is another. If Revit can do this via its scheduling tools, why can we get CE to do the same. We dont need ABD to do this, this should be possible in MS CE with item types (I think)
