Why do I need worksets to use Sheet Indexes? We don't and have never used Projects or Worksets (there is no benefit for us) but would still like to use sheet indexes. I'm sure that you can use SI in SS3/4 without using projects.
with each job folder split into the various discipline sections
ok - so it seems you have the working designs (DGNS, etc...) grouped together.
While the rest of the resources can be shared by all projects, this is not the case of a sheet index. It is specific for that set of DGNs and cannot be shared across the whole directory structure of projects you have. It has links, etc... that are specific to a particular group of designs.
So in this case, if you want to use the sheet index, you will now have a project specific item/resource.
Timothy Hickman
Main: 877 627 3772|
Unknown said: with each job folder split into the various discipline sections ok - so it seems you have the working designs (DGNS, etc...) grouped together.
Correct. All within the overall project/job folder.
Unknown said: While the rest of the resources can be shared by all projects, this is not the case of a sheet index. It is specific for that set of DGNs and cannot be shared across the whole directory structure of projects you have. It has links, etc... that are specific to a particular group of designs. So in this case, if you want to use the sheet index, you will now have a project specific item/resource.
OK. That's a shame though as the chance of changing the office workflow is not going to happen. How come you could do this with SS3/4 without projects?
