MS V8i SS5
Hello All,
I have a cell (sourcecell) in a dgn file, the cell has some tag inside. I'd like to use the cell in other files. But I don't know how to add the cell into a cell library. I have tried:
1. Attach the dgn file as cell library or open the cel library file, copy the cell by Ctrl+C/V, in this way, the original cell (sourcecell) will be a nested cell in the new cell.
2. Drop the cell, all the attached tags will gone, cannot create a new cell same as the original cell.
Does anyone know how to add a exsiting cell with tags into cell library, so it can be reused? Otherwise it almost impossible to use existing cells without the cell library. Thanks a lot!
Unknown said: MS V8i SS5 Hello All, I have a cell (sourcecell) in a dgn file, the cell has some tag inside. I'd like to use the cell in other files. But I don't know how to add the cell into a cell library. I have tried: 1. Attach the dgn file as cell library or open the cel library file, copy the cell by Ctrl+C/V, in this way, the original cell (sourcecell) will be a nested cell in the new cell. 2. Drop the cell, all the attached tags will gone, cannot create a new cell same as the original cell. Does anyone know how to add a exsiting cell with tags into cell library, so it can be reused? Otherwise it almost impossible to use existing cells without the cell library. Thanks a lot!
in your file that has the tagged cell,
Go to Element >tags > define
find the tag set in the diaog ,
File >export>create tag library
copy the cell and drop it fence file the copy out
open the files our copy
ref attach the orginal file near the new dropped cell so we can match text and levels and where the tags go
now from the The menu Elements > tags >define choose import from library now we have the tags defined use the attach tags tool in tags
now you as you can see the original cell from the ref and you can match properties you can now move the tags around to suit the right places and font style and als text settings levels etc...I would ensure they are all made visible first move around style etc then turn off those you want off by default..
Detach the ref now place fence around your dropped and tagged elements and from the cell tool add an origin ( old school method) make sure cell lib you want to use is attached and use the create cell button and your tagged cell should now work... and not nested but tags work..
Lorys
Answer Verified By: Changsong Ling
Unknown said:So MS cannot reuse cells without cell library?
A DGN file is versatile. A cell is a model; a model is a cell. A DGN file contains one or more models; a cell library contains one or more cells.
You can use a DGN file as its own cell library. Open the Models dialog and add a new model, then flick the option Ability to be Placed as Cell. Create or copy your graphics and tags into that cell/model.
Unknown said:I tried so, If I didn't drop the original cell, all tags remain, but the result cell will be a nested cell. If drop the original cell, tags are missing, the result cell is same as the original cell without tags.Thanks a lot!
That's why I gave you the long way so as to guarantee the tag integrity and not nested
I don't know if you can just copy the tags into a copy of the cell ( dropped) and xref the original cell so as to copy the tags ... if you can find out which element has the tags associated you could copy that element with its tags into the new model ( future cell) ..
How many tags we talking about here .. if you use the xref method should be easy to find where to move the tags too....
There are vba's floating around the copy and reassociate tag sets but none I've seen are free, and for you to make your own its faster to just rebuild the tags like I said ...
Why not post a copy and we can see what were talking about?
or at least a picture ... but nobody will do it for you if its a picture :) ( smile)
