How to i reset or remove the display set depth & Active depth.
i was doing some training and it asked me to set the active depth & display depth. now its set i cant see half my space.
i dont understand these tools and i have no use for them.
How do i remove them or reset them. i want to see all my space?
  • Open your Key-In Browser, and you can use the Keyins
    DP = -10000,10000
    (Sets your Display Depth to anything between -10,000 and 10,000; use any numbers you like)
    AZ = {whatever elevation you want to be drawing on}
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
    Answer Verified By: Kelly Lawrence
  • Open the View Attributes dialog for your view and make sure that both Clip Front and Clip Back are not checked. HTH
  • Ctrl+B to Open View Attributes. Turn off Front/Back Clip & Display Set.
    There are times when display depth is extremely useful but one must understand how to control them too.
    I have also been known to use DP= or DD=. DP= sets display depth to the exact values entered. DD= is a delta display depth. Each can be positive or negative. So to increase display depth by 100 in each direction, DD=-100,100. If you are actually looking at a slice of a model and wish to move forward or backwards into or out of the model, use DD=-50,-50 or DD=50,50.
    I use these a lot when working with Point Clouds from a 3D Laser Scanner.
    Charles (Chuck) Rheault
    CADD Manager
    • MicroStation user since IGDS, InRoads user since TDP.
    • AutoCAD, Land Desktop and Civil 3D, off and on since 1996
  • Hi caddcop!
    I got away from those and use the newer Clip Volume tools for the cuts etc. I will even use some of the newer Drawing Composition tools for cutting sections etc. It still uses Clip Volume. But I go back to the old tools occasionally. Having and knowing the old options and new make you more flexible. Don't be someone who doesn't want to learn more! AZ= DP= DD= & DZ= are still valid if you want them. Don't forget the Active Depth (AZ=) still has to be between the Display Depths (DP=) even with the Clip Front Back filters off.
    To see ALL your depth is almost impossible to know unless you get into your working unit settings including the Advanced area.
    I Hope This Helps Someone Reading This!  (Intergraph>PseudoStation>MicroStation user since 1980's)
