How do I change Organization Type in the Properties box in MicroStation Connect?
In Microstation 32-bit, I was able to click on Settings > Element Information, which brought up the "Element Info Dialog Settings" dialog. In this dialog, I could change the method by which elements were grouped in the "Element Information" window. The key in to make this box appear in MicroStation 32-bit was "element info dialog properties".
In Microstation Connect, the Element Information window has been replaced by the Properties window, which appears to be the same thing. But so far I have been unable to find a way to change the method by which the elements in the Properties window are grouped. The key-in mentioned above does not work in Connect.
Does anyone know a key-in to make this Settings box appear, or some other way to change the grouping of selection sets in the Properties window?
Parents Reply Children
