I am reaching out to find out if someone could help me with reporting. I have a catalog # and want to populate additional columns with look up tables. I am wondering if this is possible with MicroStation CONNECT.
Are you using plain old MicroStation CONNECT, or an application such as AECOSim?
Unknown said:I have a catalog #
Please clarify, in the context of MicroStation, what you mean by 'have a catalog #'.
Unknown said:I want to populate additional columns
Additional columns in what?
Unknown said:I to populate additional columns with look up tables
Where/what are those look up tables?
Unknown said:I have an Item Type that has a Property Definition for Catalog Numbe
Excellent innovatory use of Item Types! So you've assigned Item data to various signs in your DGN model? If so, you're also able to create a report of those data.
I don't think that there is currently a way to merge report data with data stored externally to MicroStation. You can export a MicroStation report to Excel, and perform further work from there. Where do you want to see the merged data: in MicroStation, in Excel or in a DB table?
Keith Raymond
