I have a CONNECT Report where several columns are defined, including area...
Now I want to report additionally an alternative area (Alt Area), which is the area property formatted in other units. For example, if my master units are m (meters) then area is by default reported in Sq m (square meters) for our London office. I want to generate a report that also shows area in square feet for our New York office. Is that possible?
That is, I want the report to include these data...
Answer Verified By: Jon Summers
Unknown said: Have you tried using area formatting option where different units can be used for each column?
Thanks for that hint! It's not always easy to find the options available in the Reports dialog. But, thanks to your tip, I reached a result...
