Microstation V8i (SS2) V - 08.11.07.443
Hi all,
I have 2 level libraries in my level manager that have refused to either detach or delete. Meanwhile, either of these libraries is not configured in my MSDGNLIBLIST variable as i have checked.Meanwhile, I have tried deleting/moving folders hosting the 2 libraries to the recycle bin but unfortunately this didnt work either as their levels are still present. However, these 2 libraries form part of the seed file which was used to generate the design file initially.
Can someone please advice on how to delete or detach these unwanted libraries and their levels
Thank you
In case this is still of interest:
1. Export the Level library (this will create a library with all your existing levels)
2. Attach this level library
3. Detach this library
Key-Ins:
level library export dgnlibtemp.dgnlib
level library attach dgnlibtemp.dgnlib
level library detach dgnlibtemp.dgnlib
4. The levels should be ready to be deleted.
5. if not, check locked, frozen, displaylevel set frozen off alllevel set display on alllevel set lock off all
Matthias
