Hi All,
I've encountered a bit of a strange problem.
My lines sometimes disappear when drawn, I'll notate all the details:
- My line always appears if I start it by first snapping to an object.
- My line sometimes doesn't show if I'm not snapped to an object, but I can see the units moving down the bottom almost as though I'm drawing an invisible line.
- Sometimes I can draw the line not snapped to an object, then when I end the line segment it disappears.
- Sometimes it just works flawlessly which is great.
A bit of info on my drawings, I'm working in a 3D environment. I have a lot of shared cells and a lot of information in my drawings in general. Sometimes ACS Plane Snap seems to randomly turn on (under settings - locks - ACS Plane Snap), not sure if that's me accidentally hitting a shortcut that does that or it maybe correlating to my overall problem. This occurs to me in numerous drawings, they don't always start off that way but after a while some of them just end up like that. I'm not sure why.
Any help would be greatly appreciated.
Thanks everyone.
Hi Tyson, Have you check if when this happens you are drawing a construction class line and have this turned off in view attributes? Regards
José
Construction class is an object related attribute and not exclusive for lines. You haven't told on your first post that this happens only in one view and not all of them which I had assumed. Have you tried to Keyin "copy view" from one that's ok to the bad one?
Maybe you have a display style with fill and you are drawing behind an object. This way you can see it in another view.
