Hi, I have a question about MicroStation CONNECT. I would like to change the sensitivity of my mouse. It really moves slow but I don't know how to do. I've searched in the forum and elsewhere but I couldn't find the solution. Is there anyone who had the same problem? thank you
Hello Helmuth,
Do you experience the slow mouse only in MicroStation or in general in all applications?
You can change the mouse sensitivity in Windows, for example in Windows 10 go to Control Panel > Appearance and Personalization > Mouse.Here is also a link to Microsoft page for instructions of setting the sensitivity for mouse in Win 7: https://support.microsoft.com/en-ie/help/14206/windows-7-change-mouse-settings
I hope this helps.
Regards,Anu
Hi Helmuth,
Have you tried to changed the click sensitivity in MicroStation preferences, if that would help?
In CONNECT Edition go to File > Settings > User > Preferences > Input > Click Sensitivity:
As Anu asked, did you check if this happens in another programs too or only in Microstation? This way you can tell if the problem is for example you windows mouse driver or inside Microstation.
Since you already tried the options inside Microstation and didn't work maybe you should try to upgrade your windows mouse driver. Regards
José
