Hi all,
I am facing an issue for task bar tool arrangement like Q,W,E,R. If I press Q+1 like smart line but in my window it is showing Q+1 is element selection. This task bar most of the tool are re-arranged. kindly give me solution for this issue also how to change microstation v8i select series language French to English.
Dinesh
Hello Dinesh,
Please follow this wiki article where to define the keys for position mapping https://communities.bentley.com/products/microstation/w/microstation__wiki/16739.position-mapping-is-not-working
To change the language in MicroStation V8i you need to install an English version.
I hope this helps.
Regards,Anu
Cheers,
Erik M.
