I installed my Microstation PowerDraft V8i on a new laptop with Windows 10. I tried it several times, but every time the toolbox 'Main' and 'Tasks' are not visable and not working. Also the shortcuts for these toolboxes. What is the problem?
Hi Mieke,
which version of PowerDraft V8i did you install, was that the latest V8i Ss4 version: 08.11.09.829, or have you possibly tried to install PowerDraft V8i Ss3 (08.11.09.459)? The V8i Ss3 version is not certified to run on Windows 10 (though it could work).
Did you install with administrator permissions (right mouse click on the installation program and choose: Run as Administrator).
Though you mention that this is a new laptop: was there any previous version installed already? Was that version fully uninstalled?
Are you testing with the out-of-the-box Untitled user, so without any customizations?
If you have applied your organizations' customizations on top of it, could it be that those are based on an older V8i version and that e.g. you are using a (seed) .spf/.upf file from that older version?
If so, please disable that seed preference variable (MS_USERPREFSEED), exit PowerDraft delete your current .upf file and restart PowerDraft.
See also:https://communities.bentley.com/products/microstation/w/microstation__wiki/8671.restore-microstation-to-factory-defaults Is the options Tasks ticked in your Tools menu (if you enable it, does it display when you restart) the program?
Are your WorkSpace>Preferences set like this:
HTH.Regards,
Henk
[AUTOMATED MESSAGE; if there is a link below, please follow that if you wish to respond to this Communities message.]
RE: Toolbar missing with installing on new computer
which version of PowerDraft V8i did you install, was that the latest V8i Ss4 version: 08.11.09.829, or have you possibly tried to install PowerDraft V8i Ss3 (08.11.09.459)? The V8i Ss3 version is not certified to run on Windows 10 (though it could work). I work with the latest version
Did you install with administrator permissions (right mouse click on the installation program and choose: Run as Administrator). Yes
Though you mention that this is a new laptop: was there any previous version installed already? Was that version fully uninstalled? My laptop came with Windows7 but no other Powerdraft was installed.
Are you testing with the out-of-the-box Untitled user, so without any customizations? Costomizations
If you have applied your organizations' customizations on top of it, could it be that those are based on an older V8i version and that e.g. you are using a (seed) .spf/.upf file from that older version? Yes, but with my colleagues it worsks fine.
If so, please disable that seed preference variable (MS_USERPREFSEED), exit PowerDraft delete your current .upf file and restart PowerDraft. We did, but no effect.
See also: https://communities.bentley.com/products/microstation/w/microstation__wiki/8671.restore-microstation-to-factory-defaults Is the options Tasks ticked in your Tools menu (if you enable it, does it display when you restart) the program?
Yes, but no effect.
HTH. Regards,
Did this answer your question?
Verify it as the answer or Reject it as the answer
View online
You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here. Flag this post as spam/abuse.
Timothy Hickman
Main: 877 627 3772|
does the "tools" pulldown have the "main" and "tasks" options available for you to select ? and are they showing checked or selected ? are you able to select these options outside of your custom workspace and have them stay ?
If you encounter issues clicking "View online", check here.
You received this notification because you are subscribed to the forum. To unsubscribe from only this thread, go here. To unsubscribe from a forum, please see this note.
Hi Mieke
If you have selected the Tasks from the Tools menu and the Tasks still do not appear. Maybe they are hiding behind something. Within MicroStation can you go to Windows. Is the MicroStation tasks listed as shown below. if yes select it. Does it then appear?
