problems with CE4 with display style = hidden line
1 transparency by element - not working, only transparency by level works.
2 printing to pdf - transparent objects no longer obey threshold setting in vector mode
will only obey threshold setting when in raster printing mode.
3 solids with line styles set to non-continuous only show as continuous even in wireframe.
are these problems or changes to the way MS CE works?
