Hi
see attached snap shot showing beam in group but its still not part of group.
I use group manager verify but still it showing group.
any suggestion.
While a screenshot is helpful, a DGN example would be better.
I Hope This Helps Someone Reading This! (Intergraph>PseudoStation>MicroStation user since 1980's)
I don't have ProSteel, but In MicroStation it is part of a "Named Group" of elements. The name is the Group name "Ax2449224492" containing the 3 Columns. There are 3 Named Groups. It looks like the first one "Ax2448824488" no longer has elements but the last one named Ax5592055920" has 73 elements and are the X-Bracing for the columns and the spreaders' or foundation steel pieces and connecting pieces. What are you looking to do with the Group(s)?
You can use the Drop Command to Drop the Application Element (Group) in CE.
You can Delete the Named Group of elements which will get rid of the Group but leave the individual elements.
Not sure what you want/intend to do?
