Mstn V8i SS4 v08.11.09.829 running on a Win7 machine.
I have read all about making cells to be Annotation cells. I want to go in reverse - I want to make annotation cells be plain, graphic cells. ESRI ArcMap no longer recognizes annotation cells as points (no problems with graphic cells), and all of our mapping goes into the GIS, so it's an issue.
I'm not an expert mstn user, so if you can keep it simple in explaining how to "remove annotation" from cells, that would be good.
thanks
Unknown said: (Please visit the site to view this file)Tim & George, The cells, from the cell library, are of type Graphic. they are "Annotation Cells", as per the top line in the properties dialog. They were placed with annotation on. For testing, I created a *point* cell, had it placed as an annotation cell (Model properties), but ArcGIS doesn't see it. so it seems that the key is that it cannot be annotation. I hesitate to change the cell library, but it's important to get the data into the GIS. Most of our drawings are done at 40 scale, so maybe it won't be too drastic. I'll attach the dgn - the green water valve cell is simply a graphic cell, the red are annotation graphic cells. Only the green one shows up in ESRI. it is not specific to this cell, but all annotation cells. I could use a tutorial on how to edit an existing cell library. I think I know how to create a new one. I've got the question posed on the ESRI groups as well. thanks.
thanks.
find which library.cel file has all the cells you want...
make a copy and rename it no annotation
now open the new cell.cell file as if it were a dgn
its just now a series of sub models
from the model tool the blue box like icon click on the second tick under Annotation scale icon
and turn it off next click on the file model name and open the cell
now measure how big the original cell is , determine the desired size and scale up centered accordingly
There are better more efficient ways to do this but I prefer to be cautious and leave the original as it was and tackle a copy...
this way you cant hurt any thing...
I think you can just have option to use annotation or not use annotation but if you want annotation on for text and linestyles but not cells then you best have two cell libs plus you never know how big to change your cell at placement time and for consistancy its better to decide or learn what size they are or will be by default
I like to make cells at 1m or 1 mm or 1 master unit ( not always possible ) then at placement I can just use multiples for attach at X times and would know ahead what the final size will be....
Lorys
Timothy Hickman
Main: 877 627 3772|
