I want to know if it is possible to run the compress function and the delete duplicate function as a batch file internally /externally on a large number of design files. Can it be done? If so how?
TABridges said: I want to know if it is possible to run the compress function and the delete duplicate function as a batch file internally /externally on a large number of design files. Can it be done? If so how?
Then use Batch process and add all the files that you need to do that. Always do a small test with 2 or 3 files to check if the program is working as expected.
José
