So I gound the following problems using MSCE,
Snaps:
-For some reason after some heavy use the snaps seems to go awol, the most common being the error that unables me to configure the multi snaps (it doesn't seem to check or uncheck the multi snaps settings)
-Snaps don't seem to respond in the model after some use.
- The "View Previous" after some use it doesn't work anymore
Select:
-The select by Element Template doesn't work after some use
Geographical and Solar PAth
-When I import a Google Earth Monument the Solar Path doesn't update the solar year nad the day duration.
Those are some errors I found, I hope they can get it fixed soon cause MSCE is very nice
Best Regards
Rafael
Hi Rafael, Filed Defect 693204 for multi-snap issue. Please provide a test case and steps for 'Select' issue Thanks for reporting, Manoj
