MicroStation CONNECT Update 5 online help tells us the Minimum Profile required to install and use MicroStation. It contains a link to this URL.
That Bentley Systems web page describes the minimum hardware requirements for MicroStation V8i. Those minimum requirements are incorrect for MicroStation CONNECT. For example, none of the 32-bit variants of Windows is valid.
