Hi
Do we have a key-in to toggle the clip volume off / on? Basicaly i would like to set up a single f-key to turn on / of the view attributes clip volume button. Im using microstation connect U5
Helge
Hi Helge, Try with: VIEW CLIP [ SINGLE | CLEAR ] If you create a function key with this key-in VIEW CLIP SINGLE you only have to choose the object to activate the clip.
Then create a function key with this key-in VIEW CLIP CLEAR, you only have to choose the view where you want to turn off the clip.
Hope this helps. Kind regards
José
Answer Verified By: helgeh
With the same keyboard key-in I don't know if you can have a function to turn on/off the clip.
Even with Ian suggestion you have to use 2 functions and these don't work well with more than one view.
Of course for this key-in to WAD first you have to have a clip already created in your model.
As I stated before, to turn on the clip, you have to press the function then you have to select the intended clip object (this also works with simple box elements).
To turn it off select the second function key then accept in the intended view (the clip is turned off in all open views).
For me this is better as it supports more options.
