Is there any way i can print a bing map aerial raster using microstation?
Unknown said:I just tried 150, 200 and 300 scale
1"=150' is 12x150 (1 foot = 12 inches; 1' = 12"). That's 1800.
Let's star with the basic.
1 - Do you see the raster image in print preview?
2 - You can set level to rasters. If this level is non printable you don't get this in output - Level Manager:
3 - You can set raster objects to print or not independently from the level - Raster Manager:
Maybe this should be moved to https://communities.bentley.com/products/microstation/microstation_printing/
José
