In SS2 when a reference file was not found it would display in RED but the Display toggle for the reference file would still be toggled on.
In SS4 when a reference file was not found it would display in RED but the Display toggle for the reference file is now toggled off - why did this behavior change?
We have some specific seed files we have set up with dummy reference file names and the user goes in selects the file and browses to their project folders and replaces the dummy file with their own and the setting for level symbology display settings etc. are preset for them and they are done now they need to toggle on the display setting as well not a big deal but its now an extra set and can't figure out why you would change behavior
I can reproduce it with ease. see capture
Dan
PowerGEOPAK SS10 and ORD
ok - I am confused here.
I opened the file you supplied in SS4 and the displays were off for the references.
I uninstalled SS4 and installed SS3, then opened the file and again the displays were off.
I uninstalled SS3 and installed SS2, then opened the file and again the references displays were off.
So in ALL cases, the file you supplied had the display off for the references.
So I don't think the issue is as you are stating.
Can you open a file in SS2 where they are showing displayed and not found ? and that same file shows different in SS4 ?
Timothy Hickman
Main: 877 627 3772|
using untitled workspace in both PowerGEOPAK versions SS2 and SS4
Same file this is SS2 display toggle is on
ss4 - again untitled workspace same exact file reference file display is off
