How should I make a B-Spline surface to become a solid, like the same function of replace surface in MicroStiation V8i?
Could you tell me please, thanks!
regards
Koalar
Please follow the MicroStation Programming forum best practices.
Are you writing MDL, C++, C#, VB.NET or MicroStation VBA?
When you post code, use the Forum advanced editor's syntax highlighting tool. That's the icon that resembles a pencil:
Unknown said:function of replace surface in MicroStation V8i?
Please be specific: what function in what API in MicroStation V8i?
Unknown said:this question should be under MicroStation list
Then please post to the MicroStation Forum.
Koalar,
Unknown said: I wish to know which function in MicroStation Connect can do the same work as it's in MicroStation V8i: Solid Modeling-Replace Face.
It appears "Replace Face" is still present in MicroStation CONNECT, though moved to a new location in the interface.Please see this post: How to open some V8i tools that seem deleted in Connect Edition
I will move this thread over to the MicroStation product forum.
HTH,Bob
Answer Verified By: Koalar Q
